Traynor YGM 3 Tremolo trouble
Markusv
Post by Markusv »
Hello everyone.
It has been over a year since I have been active here.
I have gotten rusty with amps and hardly get to tinker around much any more, so I am hoping to get some short cut advice. My YGM3 Tremolo doesn't work. Actually I bought it not working. The tubes are good so that can't be it. The pots are fine and the wiring seems to be all in place.
Question: What typically makes these tremolos die? Do caps fail, or is there something more sinister?
Thanks as always
Markus
.........Now where did I put it?
Re: Traynor YGM 3 Tremolo trouble
Markusv wrote: Thu Apr 29, 2021 12:11 amWhat typically makes these tremolos die? Do caps fail, or is there something more sinister?
Welcome back! Yes, any electrolytic caps in the tremolo circuit are suspect.
Markusv
Post by Markusv »
Thank you Xtian. Will check tomorrow. I suspect that would be a tremolo tube cathode cap?
Leaky phase shift caps are also a common failure mode.
Markusv
Post by Markusv »
Thanks -- so the 3 caps in successive CR configuration?
Thx Martin
Yes.
