6505 mods
Jackstraw89
6505 mods
Post by Jackstraw89 »
So I recently came into possession of a 6505 combo. It’s not working. So a tech friend and I are gonna have to crack it open anyway. While we’re in there I was thinking we could mod the clean channel to something a bit more interesting. I’ve heard Soldano has a great clean circuit, as does Dumble. But does anyone else have any thoughts?
sluckey
Re: 6505 mods
Post by sluckey »
Fix it as is before you do any mods.
Re: 6505 mods
Post by Stevem »
These amps typically blow out output tubes which then in turn open up the screen resistors and blow the V+ fuse.
Be sure to look at the tube socket solder connections to that output tube board while you have it out and are replacing those 470 ohm screen resistors.
