Ruby Amp Speaker Output jack
bzblues
Post by bzblues »
Hello everyone!
I've built a Ruby amp, the amp works fine and sounds very cool! the thing is that I wanted to add a speaker output jack to the circuit but it didn't work. I plug it to a 6 ohm speaker and also to a Roland Street Cube amp but no sound came out of them. Is the wiring OK? I'll attach the picture.
Disclaimer: I'm very new in electronics so my knowledge is little.
Thank you!
sluckey
Re: Ruby Amp Speaker Output jack
Post by sluckey »
The red wire from the board out should connect to the jack lug marked with a "T".
SoulFetish
Post by SoulFetish »
your jack is wired backwards. should look like this:
