Is there a way to calculate the bias voltage required to run an output tube (or pair) at a given wattage?
If someone can create a spice model for a 6L6GC it seems like I ought to be able to crunch a few numbers and come up with a range of voltages to design a bias circuit around.
I've been searching the interwebz for answers and all I can find are regurgitations of ohms law.
Calculating bias voltage requirements
Re: Calculating bias voltage requirements
Look at the tube data sheets. For example:
https://frank.pocnet.net/sheets/127/6/6L6GC.pdf
For Push-pull class AB, see given plate and screen voltages, and Grid #1 bias voltages.
Now, in practice, our amps usually have screen voltage much closer to plate voltage, and higher (more negative) bias voltages. But, hey, you asked for documentation.
- clarkleach
That's not what I asked.xtian wrote: ↑Sun May 17, 2020 2:59 am Look at the tube data sheets. For example:
Now, in practice, our amps usually have screen voltage much closer to plate voltage, and higher (more negative) bias voltages. But, hey, you asked for documentation.![]()
It's easy to estimate it for 6L6GC class AB amp. You want your bias voltage to be about tenth of your screen voltage. So if your screen voltage is 400V, -40V bias voltage is usually going to be pretty close to what you want.
