A "dumb" calculation by me would say ok the B+ is 500V, that means 30/500 = 60 mA. This obviously isn't correct, as the B+ will sag at full power, and of course the screens draw some current also and they are at a lower voltage, say 450V. It also doesn't take the bias into account, which obviously is crucial to the difference between the amp producing any output at all.
What is the correct formula for calculating this, assuming you know the bias point, the idle b+ voltage, the idle screen voltage, and the tube type?
I'm fairly certain it involves taking a datasheet of a "close" idle screen voltage, and then scaling the datasheet somehow (how is this accomplished?) to match the correct idle screen voltage, then drawing a sine wave on the datasheet from the bias point to 0V, then somehow calculating the current from that, but I'm not sure, and I can't remember where I read all this years ago.
Is there a simple formula for 6L6s? Or is there a tool somewhere that makes this process easier?
Thank you!
