YCV50 PT DC Heater Circuit
ncusack
Post by ncusack »
Hello,
I a have a set of transformers from a YCV50 I'm looking to build a Trainwreck out of. The PT specs are 0-300V @0.2A,0-6.3V @3A and 0-28V @0.2A. On the YCV40 they use a bridge rectifier on the 28V tap and a 24V LDO to get 24V DC for the SS reverb and run the rectified3 28V through 2 parallel 100ohm resistors in series with the two preamp tubes heaters. By my calcs that would be 28v x 1.4 = 39.2VDC less 15VDC from across the resistors leaving 24.2V for the two preamp tubes at 12V each.
Now since I plan to build an Express amp and only need the DC heaters for two preamp tubes before the PI could I just use an artificial center tap on the 0-28V tap and fullwave rectify and regulate with a 12V LDO (7812)? I like the idea of parallel heaters instead of the series heaters the YCV50 uses. I am also curious about lead dress with the DC heaters in an express build.
If anyone can confirm my thinking or provide any other thoughts it would be great.
Neill
sluckey
Re: YCV50 PT DC Heater Circuit
Post by sluckey »
The idea of artificial center tap on the 0-28V tap and fullwave rectifier won't work. And the two parallel 12v filaments would want 300mA but the PT only has 200mA rating. I think the YCV40 plan is a better choice.
S Luckey is right- you may not have enough current available on the 28V winding, since you will be asking about twice as much current as it was providing originally. To be safe, I would do exactly as the Traynor schematic. Do not add an artificial center tap when using a FWB rectifier.
