Hello All! I picked up this gem on ebay for a challenging resto. Does anyone have a schematic or a tube layout? I went to Dr. Tube. One of the few schematics that are not in the system. It came with 3 EL34s & a 6L6 with a solid state rectifier.
Thanks in advance!
MIYUKI ELK Custom 150 Head
- Leo_Gnardo
Re: MIYUKI ELK Custom 150 Head
Howdy naybah! My, that looks like it's been a mouse condominium... gonna take some cleaning up. What few Elks I've seen copy Fender circuits. The larger amps use EL34 or 6CA7 instead of 6L6. When it comes to what needs to be replaced, it's all the usual suspects: electrolytic AND film caps, drifted resistors, corroded connectors, dodgy tubes & maybe some funky sockets. At least the face plate looks kool, with two (!) meters. Of course, that 6L6 likely doesn't belong, and the white output tube is full of air. One of the EL34's has "Made in England" likely a Mullard. Not that it's gonna help win any prizes. You'll be best off replacing the outputs with a new matched set once everything else has been squared away.Junkin8ez wrote: ↑Mon Nov 12, 2018 1:11 pm Hello All! I picked up this gem on ebay for a challenging resto. Does anyone have a schematic or a tube layout? I went to Dr. Tube. One of the few schematics that are not in the system. It came with 3 EL34s & a 6L6 with a solid state rectifier.
Thanks in advance!
- Tony Bones
Very cool piece! All wirewound resistors!
Looks nice on the underside! Good luck!
- Tony Bones
Looking at the few schematics at Dr Tube, I noticed that the Viking Bass 100 has a triode wired EL84 driving a quad of EL34 with an interstage transformer - parafeed no less. You can see the transformer on the underside of your chassis.
Thank you all for the quick responses!
I am sure you will see this eventually!Leo_Gnardo wrote: ↑Mon Nov 12, 2018 3:43 pmHowdy naybah! My, that looks like it's been a mouse condominium... gonna take some cleaning up. What few Elks I've seen copy Fender circuits. The larger amps use EL34 or 6CA7 instead of 6L6. When it comes to what needs to be replaced, it's all the usual suspects: electrolytic AND film caps, drifted resistors, corroded connectors, dodgy tubes & maybe some funky sockets. At least the face plate looks kool, with two (!) meters. Of course, that 6L6 likely doesn't belong, and the white output tube is full of air. One of the EL34's has "Made in England" likely a Mullard. Not that it's gonna help win any prizes. You'll be best off replacing the outputs with a new matched set once everything else has been squared away.Junkin8ez wrote: ↑Mon Nov 12, 2018 1:11 pm Hello All! I picked up this gem on ebay for a challenging resto. Does anyone have a schematic or a tube layout? I went to Dr. Tube. One of the few schematics that are not in the system. It came with 3 EL34s & a 6L6 with a solid state rectifier.
Thanks in advance!
- Leo_Gnardo
Well so much for the "Fender copy" theory. Junkin' had another Japanese amp he posted here a couple years ago. Made to look like a blackie Fender on the outside, it was a copy of a brownie Vibrolux on the inside. Turned out to be a pretty darn good amp!Tony Bones wrote: ↑Mon Nov 12, 2018 5:28 pm Looking at the few schematics at Dr Tube, I noticed that the Viking Bass 100 has a triode wired EL84 driving a quad of EL34 with an interstage transformer - parafeed no less. You can see the transformer on the underside of your chassis.
Thanks for posting that schemo Tony, and I'll have to put Dr. Tube on my list of schematic sources.
