Pop when taking off Standby
Emetal
Post by Emetal »
Although I waited sufficient time after turning the Power on, Laney VH100R pops when taking off Standby. This happens even if after hours of playing I turn the Standby On and then Off to play again, it pops again. I tried changing the tubes, all pre-amp 12ax7's and power tubes 6L6's or EL34's so it is not the tubes. Happens all the same. Any ideas or expiriences please.
Re: Pop when taking off Standby
Your amp does not have a tube rectifier, right? Don’t worry about it. Better yet, don’t use the stand by switch at all.
Roe
Post by Roe »
common solutions are either a 100k+ power resistor across the standby switch or grid resistors on the power tubes
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Emetal
Post by Emetal »
UPDATE !!!!! Problem is developing further, when I take it off Standby there is three options now:
1. No sound at all, nothing happens,
2. Just hum, noise
3. Pops but works again...
I am suspecting the actual Standby Switch is gone bad ? I checked the diodes right after the switch, they are conducting in one direction, not conducting in other. So diodes are OK.. Any other ideas?
pompeiisneaks
Site Admin
Post by pompeiisneaks »
Emetal wrote: Fri Mar 09, 2018 5:01 pm UPDATE !!!!! Problem is developing further, when I take it off Standby there is three options now:
2. Just hum, noise
As xtian noted, just don't use the standby, it's not needed. If you feel it could be the culprit, though, you could try seeing if you can get some deoxit inside, the snapping often indicates arcing due to the contacts not switching in fast/smoothly enough, and no power occasionally could mean some build up of gunk on the contacts. Standby switches are a poorly designed mute and not needed anyway.
~Phil
tUber Nerd!
Just jump the switch and power it up that way.
Post by Stevem »
X2 your standby switch is failing.
Emetal
Post by Emetal »
Yeap, it was the switch! I know the amp is OK without it but I just got a brand new one today anyway, just to keep the amp in original shape if I ever wanna sell it, buyers are weird that way :-) Everything is perfect and silent now. Thanks everybody :D
