Amp Phase - Am I going mad?
- Littlewyan
I've always read that a Trainwreck Express is in phase and I've taken that as the output is in phase with the input, however looking into it I don't think that's true? If you go through the gain stages it seems that the output is out of phase with the input.
Also reading some information written by Ken Fischer regarding the JTM45 he says they are out of phase. But again, go through the gain stages and you'll see that they are in phase?
https://books.google.co.uk/books?id=kxt ... se&f=false
Am I looking at this wrong? The output of a LTPI Power Amp will be in phase with the input of the LTPI, so if you have an even number of gain stages prior to it then the output will be in phase with the input, is that right?
Re: Amp Phase - Am I going mad?
I may be wrong, but off the top of my head I would say both amps are out of phase at the speaker input!
- Littlewyan
How so? A JTM45 has one less gain stage (cathode follower won't flip the signal)
- norburybrook
Phase is always relative so does it matter? if you have more than one amps then yes
M
M
My reckoning is that the speaker output on the Express is out of phase with the guitar input, and in phase with it in the case of the JTM45. People have claimed to hear a difference when swapping the speaker leads on a combo amp, which I think might have to do with feedback from the speaker to the amp chassis and its electronic components.
Last edited by martin manning on Thu Mar 01, 2018 3:48 pm, edited 1 time in total.
frankdrebin
I think i have read somewhere (maybe the Doyle Marshall book) that jtm45 and Bassman were opposite phase,i think the speakers were reverse polarity in Marshall.
frankdrebin
i think so,when you pick at loud volume,the first impulse is the biggest and in an open back cab in a small ambient can really make a difference because of reflections having different timing.martin manning wrote: ↑Thu Mar 01, 2018 3:45 pm By my reckoning is that the speaker output on the Express is out of phase with the guitar input, and in phase with it in the case of the JTM45. People have claimed to hear a difference when swapping the speaker leads on a combo amp, which I think might have to do with feedback from the speaker to the amp chassis and its electronic components.
I agree with your analysis, the JTM45 looks to have its output in the same polarity as its input, whereas with the Express (having an additional inverting gain stage), its output looks to be in opposing polarity to its input.
Note that when implementing a circuit, it's trivial to flip signal polarity at the speaker jacks, provided a type that is isolated from the chassis is used.
- norburybrook
I think matchless combo's had a speaker phase switch.pdf64 wrote: ↑Thu Mar 01, 2018 3:52 pm I agree with your analysis, the JTM45 looks to have its output in the same polarity as its input, whereas with the Express (having an additional inverting gain stage), its output looks to be in opposing polarity to its input.
M
I added a switch to the back of a 4x12 to phase flip when using an Expressnorburybrook wrote: ↑Thu Mar 01, 2018 5:20 pmI think matchless combo's had a speaker phase switch.pdf64 wrote: ↑Thu Mar 01, 2018 3:52 pm I agree with your analysis, the JTM45 looks to have its output in the same polarity as its input, whereas with the Express (having an additional inverting gain stage), its output looks to be in opposing polarity to its input.
M
- Littlewyan
Ok so we've established that the Express is indeed out of phase with the input, so why does Ken say it's in phase? And then say the JTM45 is out of phase?
frankdrebin
Because he used the magic property of the vacuum cleaner cord? LolLittlewyan wrote:Ok so we've established that the Express is indeed out of phase with the input, so why does Ken say it's in phase? And then say the JTM45 is out of phase?
Inviato dal mio Redmi 4X utilizzando Tapatalk
Source? Are you sure it wasn't (and correctly) the other way around?Littlewyan wrote: ↑Thu Mar 01, 2018 9:07 pm Ok so we've established that the Express is indeed out of phase with the input, so why does Ken say it's in phase? And then say the JTM45 is out of phase?
- norburybrook
Interestingly.....or not... I used my Express with my #102 and they were both in phase at the speaker.
Marcus
Marcus
- Littlewyan
Admittedly I can't find the source for the Express being in phase, maybe I heard it from someone on here. However in the original post you'll find a link to a Gerald Weber book where Ken says the JTM45 is out of phase.
