6AU6 vs. EF86?
Alexo
6AU6 vs. EF86?
Post by Alexo »
6AU6's are incredibly cheap and easy to find in many an old radio, I have about 8 or 10 in my stash right now, all of which I came across by accident, versus 0 EF86's I've been able to find, so...
Does anyone have experiences with these? I am embarking on an 18watt-ish amp that will have one 6AU6 channel, in hopes that it may capture some of the magic of the EF86 at a much smaller cost (and socket ;))
Do they sound similar to EF86's? The datasheets have a lot of very helpful info, but I would appreciate any tips anyone has for wiring them up, I've attached the schematic I've worked out, how's it look?
...Thanks!
Johnhenry
Re: 6AU6 vs. EF86?
Post by Johnhenry »
go to schematic heaven and look at a 303a or a 303 Harmony amp in the Bargin Bin Amp section, one of the version's used the 6au6 tube on the input.
johnhenry
Alexo
Re: 6AU6 vs. EF86?
Post by Alexo »
Thank you , Johnhenry.
After further research, I have found references to the 6AU6 being terrible for audio and also maybe needing DC filaments to avoid excessive hum.
I think I'm just going to bite the bullet and order a couple EF86's but I'll find a use for all those 6AU6's one day... that gain of 300's gotta be good for something.
klingo
Re: 6AU6 vs. EF86?
Post by klingo »
http://www.valvewizard.co.uk/ again
the guy says pentodes are good CCS's(Constant Current Sinks) and that in this application we haven't to worry about noise or microphonic.
there's a interessing pentode "tail resistor" for schmidt PI in this link(go to Constant Current Sinks)
cheers
Aharon
Re: 6AU6 vs. EF86?
Post by Aharon »
Here's a link to the HWY 86..............this amp has been built and there's a report somewhere on the net.
6Au6 input and ECL86 PI and PA.
http://www.harmonicappliances.com/highw ... -86-a1.pdf
Aharon
Aharon
Aharon
Re: 6AU6 vs. EF86?
Post by Aharon »
Thanks klingo,like a dummy I forgot the link,all fixed now.
Aharon
Aharon
lastwinj
Re: 6AU6 vs. EF86?
Post by lastwinj »
i've been spouting off about the 6AU6 for about a year as a SMART alternative to the ef86.
its a great tube, built up an amp with one in the front end about 4 years ago. VERY nice sound.
no microphonics, either.
germ
