Need help with Tone Stack Calculator
deepmojoman
Anyone here ever used the Duncan Tone Stack Calculator? I don't know how to figure out the Source resistance and load impedance.
Anyone here know how to do this?
Re: Need help with Tone Stack Calculator
As a source impedance, the options are:
38 kOhm if the eq is plate loaded
620 Ohm if the eq is cathode loaded
The load impedance is usually 1 MOhm when you have only one master volume of 1 MOhm, or 500 kOhm if you have two pots in parallel of 1 MOhm each.
(deleted)
You are right matt, I referred to the classical 12ax7s plate driven TS with 100k Rp, 1k5 Rk plus Ck, and the other classical CF with 100k to ground, as they cover 99% of the cases.
(deleted)
deepmojoman
OK-thanks for all that info (especially the Preamp Output Impedance Calc-very helpful!)
So: how would I convert the Tone Stack Calc to a single Tone Knob Tone Stack?
(deleted)
deepmojoman
Thanks-which one is BMP? Is that Big Muff?
The Ballzz
I just recently played with Tone Stack Calculator for the first time and, IIRC, the source impedance does not have a dramatic effect on the curve generated by changing the other values. I coild be wrong and I'll play with it again when I feel like opening my poor old Mac laptop in Windows.
Gene
Gene
(deleted)
Ahem... 2x difference. :^)matt h wrote:6db, you say, not a big deal. Until you view that as signal voltage--at which point it's a 4x difference.
(deleted)
Voltage goes like the square root of power, -6 db is 1/4 power, (1/4)^0.5 = 0.5.
(deleted)
