Plate voltage probe
beasleybodyshop
Plate voltage probe
Post by beasleybodyshop »
so i have a small collection of bad octal tubes, and some nice new sockets laying around, and i want to build a probe to check the plate voltage without opening the amp up.
My question is, would i wire it across pins 3 and 8 - as in one lead on pin 3 and one lead on pin 8? or would i just run one lead to the plate, and the other lead i clip to the chassis?
Re: Plate voltage probe
Post by Stevem »
You could do it either way, but I would choose to have a wire also on pin 4 the screen.
billc
Post by billc »
another good option is a tube extender, a relatively safe way to check voltages
[img:600:800]https://lh6.googleusercontent.com/-yuR4 ... 154911.jpg[/img]
Those tube saver gizmos aren't expensive. Given the high voltage and potential danger, I'm not sure I'd want to use a home grown device. One slip is all you might get.
