Univox U-45
sepulchre
Univox U-45
Post by sepulchre »
I just found this video: https://www.youtube.com/watch?v=H27QxL8A4Qc
That's the first amp I ever owned. I thought it sounded pretty good then and this video makes me think I was right. So I'm considering building one. I found a schematic (attached) but, though it doesn't show the HT, it does show the PT secondary at 250-250 at 50 mA. I'm unfamiliar with 6BM8 tubes but I'd bet I could get NOS examples for cheap. The 12AX7 is only used for the tremolo! And the 6X4 is common enough, I think. I even found a modded schematic that allegedly gets it closer to the Gibson GA8-T it's supposed to be patterned after.
There's a U-45 and a U-45b. I don't know the difference - some say the 45 is single ended and the 45b is p/p. The schematic here is the 45b. The one in the video looks just like the one I got when I was 15 (used - a year old) so I'm thinking that mine was the 45b.
Anyway, just wondering if anybody has any experience with these or thoughts about them.
joshdfrazier
Re: Univox U-45
Post by joshdfrazier »
hmm 6bm8, i'm pretty sure those are 1/2 pentode, 1/2 triode. preamp and output in a single package! I'm a huge fan (maybe this is obvious lol) of univox amps. I have played through a PP U45, and they are really great sounding amps. However, I would try to snag an original on ebay. I see these go for no more than $300 from time to time. You can't build "mojo" haha.
sepulchre
Re: Univox U-45
Post by sepulchre »
Well I can't afford $300 for an amp that will mostly be something just to play around with. I've got amps and couldn't get past the wife factor for that kind of cash - too close to retirement.
So I'm going to give it a go. I bought a matched pair of NOS 1970 Svetlana =C= 6BM8s (6F3P), and an NOS American 6X4, 60s I think. Coming up with a chassis shouldn't be too hard and there's lots of parts in the cabinet. So now I'm looking at iron - maybe Edcor or Classictone. I think I can get it to sound decent enough with a little TLC.
statorvane
Re: Univox U-45
Post by statorvane »
Guys over on PPwatt are doing some interesting stuff with 6BM8s.
FYI.
sepulchre
Re: Univox U-45
Post by sepulchre »
Thanks! Maybe they can point at some appropriate iron.
This needs a 16K primary 15 watt pp OT. I'm not too swift with iron so, if I were to use an 8K primary with a 4R secondary but hook it to an 8R speaker to get 16K at the primary would that half the wattage rating?
jazbo8
Re: Univox U-45
Post by jazbo8 »
sepulchre wrote:Well I can't afford $300 for an amp that will mostly be something just to play around with. I've got amps and couldn't get past the wife factor for that kind of cash - too close to retirement.
I found it is hard to build an amp that looks and sounds comparable to the original - certainly not for $300. Yes, I could build one for less money (not counting the time invloved) when the circuit is relatively simple, but by the time I factored in the cosmetic then it is usually a borderline case - and as mentioned there is no mojo factor - it's just another DIY amp. So I would put the cut-off point at perhaps $500-600, below that it just does not seem to "add up"... Just my 2c. :wink:
sepulchre
Re: Univox U-45
Post by sepulchre »
Really? Where would all that money go?
After checking around I've found iron for under $100, both PT & OT. The tubes were $38, NOS no less (not the 12AX7, I've got a few of those to choose from). I already have the pots, resistors and most if not all of the caps. Scrounging up a decent chassis will be cheap or free. Again, I have stuff around here.
I'm not concerned with the look. I suppose an elaborate combo cab could take a few bucks. But I can make a nice head cab for it with the scrap in my shop and plug it into existing speakers - got a perfect 1X12 box with a Greenback ready to go.
So I'll give it a go. If it works out well I'll post a clip. If not, well it'll be fun trying. But think it will sound just fine.
Btw, I think you can build mojo. Ohm's law works the same on my bench as it does on HAD's or KF's.
Re: Univox U-45
Post by Stevem »
Check that U45B schematic again, that first section of the AX7 is the first gain stage, the second section is the trem oscillator
jazbo8
Re: Univox U-45
Post by jazbo8 »
sepulchre wrote: I'm not concerned with the look.
The Look - that's the hardest thing for me - I can't build chassis or cabinets worth a sh*t, they just always look amerturish, so I really had to buy them already made which add greatly to the build cost.
By "mojo" I did not mean the electronics part, but rather the overall package, so again for me, if I can get a great looking/sounding vintage amp for $300, I think I'm actually saving money, obviously YMMV. :wink:
sepulchre
Re: Univox U-45
Post by sepulchre »
Stevem wrote:Check that U45B schematic again, that first section of the AX7 is the first gain stage, the second section is the trem oscillator
Yes, I saw that. But I think a good modern AX7 should do okay. If I had an NOS one laying around I'd throw it in but that's not the case.
@Jazz: Okay, gotcha. I love my wood shop and I feel sure I could do a combo box justice but for this project I think a nice looking head cab will do.
Thanks, guys! I'll post results as they occur. Might be a little while though. Gotta get through the current "To-do" list.
sepulchre
Re: Univox U-45
Post by sepulchre »
One question: the schematic shows the OT primary at 16K, kind of hard to find. So would 10K work alright? I see them used with EL84s which I believe have similar requirements to the 6BM8.
joshdfrazier
Re: Univox U-45
I believe the el84 has a much higher plate resistance than the pentode inside of the 6bm8. In my experience, not using the right OT for the job has resulted in bad/weird/useless tone. With that said, if you have the 10k OT on hand, it never hurts to try...
sepulchre
Re: Univox U-45
Post by sepulchre »
Hmm. I missed that on the data sheets. No, I don't have one, but they're easy to find. So I'll keep searching. Thanks!
Re: Univox U-45
Post by Stevem »
The rule of thumb on OT impedance is to take the tubes plate resistance spec and take 1/5 to 1/10 of that and things will work and not sounds like crap.
Default
Re: Univox U-45
Post by Default »
I have the Realistic version of that amp, but with a 12" Jensen. It's a killer amp for low volume grind and I paid $175 for it. Check Fleabay and craigslist for Realistic and Lafayette guitar amps. They are Univoxes but sell for even less.
If it won't kill me by taking it into the bathtub, I don't want anything to do with it!
