D'Lite cab dimensions
I have a D'lite kit that I bought when they first came out, yes, about 7 years ago. Trying to find info on the wide combo cab that was sold to accommodate it. Any help? Id like to get a good drawing if possible, if not a cabinet that hasn't been used. haven't had much luck on brownnote.net. Thanks in advance.
Re: D'Lite cab dimensions
My notes say:
widebody Cabinet Dims. Are: 24" WIDE x 20" TALL x 9.5" DEEP
I have no idea at this point where I copied this from.
Paultergeist
Otter pop,
I don't know if mine is what you are looking for, but I installed my D'Lite 22 in the combo cabinet that was being recommended by the Brown Note folks back when they were still doing business. I believe it was built by Anthony Reason -- he may still be around (Reason Amplification?) -- and if so, he might be able to help you.
If I recall correctly, somehow the measurements of the chassis mounting screw holes got wrong, and I had to re-drill about 1/4" from the original built cabinet. I had to use big fender washers to hide the duplicate set of holes.
If all else fails, I can at least assist with a photo or two of mine.
thanks, I'll look in to it.
Take a look at Anthony's Stagecraft web page too, he now has rack cabs and does custom work.
Reason Amps, Gabkits, StageCraft are all done by Anthony.
amplifiednation
I've built one or two of these. I think they are 17" chassis??? The cab would be just over 18.5", maybe 18.75" with tolex
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
