Morgan RCA35
beasleybodyshop
Morgan RCA35
So, I was looking at the gut shot for one of these Morgan Amps, and this is what im thinking i see:
tweed deluxe preamp with a long tailed phase inverter
split cathodes on v1 a la plexi marshall
master volume control that you can defeat from the circuit
standard fender TMB tone stack
all being fed into a 6L6 power amp section - without seeing the transformers (it says its a 35 watt amp) maybe using something along the lines of a 40 watt bandmaster or super power transformer? Just trying to wrap my head around this one.
Re: Morgan RCA35
I don't know.
But, is anyone else bothered by the lead-dress on the three items marked with a red x in the attached photo?
- Milkmansound
Re: Morgan RCA35
They took great care to mout that cathode ground resistor for the finals on top of the bypass cap maybe forgetting that the whole amp turns upside down - that's a recipe for a dry cap!
The flying lead stuff doesn't bother me so much so long as they wrap them tight around the lugs before soldering
- randalp3000
Re: Morgan RCA35
It might look something like this, but you didn't get it from me
however that one has a pull bright
tweed baseman/marshall preamp without cathode follower driving tone stack.
- Leo_Gnardo
Re: Morgan RCA35
Roasting el caps with nearby hot resistors was done by plenty of commercial builders too so just following the norm.Milkmansound wrote:They took great care to mout that cathode ground resistor for the finals on top of the bypass cap maybe forgetting that the whole amp turns upside down - that's a recipe for a dry cap!
When they wrap the wire on & forget to solder, that bugs me. Seen it happen a lot. Heck even I've done that... put head-slap smiley thing here.The flying lead stuff doesn't bother me so much so long as they wrap them tight around the lugs before soldering
Re: Morgan RCA35
Nearly every gut shot I've of this manf across different models, seemed like there was a race to get it assembled in 30 mins.
TM
TM
- randalp3000
Re: Morgan RCA35
I feel the same way. I've seen 2 with wires not soldered in pots.ToneMerc wrote:Nearly every gut shot I've of this manf across different models, seemed like there was a race to get it assembled in 30 mins.
TM
found one
- VacuumVoodoo
Re: Morgan RCA35
This. And over half of solder joints fail already on visual inspection.NickC wrote: But, is anyone else bothered by the lead-dress on the three items marked with a red x in the attached photo?
Also, where is protective earth cable attached?
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
Re: Morgan RCA35
I was thinking the same thing, pretty poor craftsmanship for $1700, even if it was only $700.VacuumVoodoo wrote: This. And over half of solder joints fail already on visual inspection.
TM
- randalp3000
Re: Morgan RCA35
OMG I forgot, it's a copy of the 18 Watt Superlite TMB pre with a couple very small tweaks.
Re: Morgan RCA35
What kind of power section is this exactly? This really looks like a superlite a lot. Does anybody know what changes should be made to the superlite schematic to run it with 6l6? I would use a Bassman power and output transformer probably.
Re: Morgan RCA35
Ahh just saw the schematic. Great !
Re: Morgan RCA35
That schematic has "350-0-350 unloaded" written on it, but then 370V for the first power supply node, which doesn't add up to me unless I'm missing something?shocki wrote:Ahh just saw the schematic. Great !
beasleybodyshop
Re: Morgan RCA35
Randall, was there some sarcasm font tossed in there lol?randalp3000 wrote:OMG I forgot, it's a copy of the 18 Watt Superlite TMB pre with a couple very small tweaks.
since i started this post, ive been inside two of these. I definitely agree with the comment that someone made about these things being assembled together in 30 minutes. The two that i looked into both had wires that were literally one nudge from breaking off.
Re: Morgan RCA35
Yeah but, but, but, but, it has Sozo's and Mercury transformers!
