VOLTAGE DOUBLER FOR POWER SUPPLY
ampfab
Post by ampfab »
I have a power transformer out of an old Wurlitzer organ that powered 4 7591 power tubes and about a million 12ax7s.
the original power supply used a voltage doubler.
would this doubler circuit work well, also provide a "half power" supply?
I'd like to use it to power a pair of 6550s.
Congress Park Amps
Re: VOLTAGE DOUBLER FOR POWER SUPPLY
I don't see why not, but I would add some balancing resistors across the stacked caps for the half-power mode.
Kagliostro
Post by Kagliostro »
To me no, resistors are not to be used
the resistors are to be used if you have the cap in series as when the switch is open, but if the switch is closed ???
But why to have 1 x B+ and 2 x B+ alternatively ?
also if you can do that, what will be at the plate of the preamp tubes, do you want to run also those at 1/2 voltage ?
K
Kagliostro wrote:To me no, resistors are not to be used the resistors are to be used if you have the cap in series as when the switch is open, but if the switch is closed ???
I don't see any problem with the resistors being there when the switch is closed. The caps will still share voltage equally.
Kagliostro
Rethinking about that with the switch closed the resistors will act as bleed resistors, so may be there is no contraindications
K
Danny_J_Glover
Post by Danny_J_Glover »
ALWAYS INSTALL BLEEDER RESISTORS ON HIGH VOLTAGE CAPS.
"I am certainly of opinion that genius can be acquired, or, in the alternative, that it is an almost universal possession."
Kagliostro
I would like to know
K
Halving the B+ will cut the power in the same way as whole-amp "power scaling," which some people like.
starlite2991
A bleeder resistor
Post by starlite2991 »
I concur. About a 150k 1 watt would be needed for the bleeder resistor. Not having one is like playing with fire
Danny_J_Glover wrote:ALWAYS INSTALL BLEEDER RESISTORS ON HIGH VOLTAGE CAPS.
I know I ask a lot of questions but to not ask is a crime!
Kagliostro
May be, but the most part of people didn't like it and prefer to lower the voltage only to power tubes and PI
So my council will be to have from the same PT a branch with constant voltage to be used to supply the preamp tubes
one other bridge, some cap and resistors and it is done
K
Firestorm
Post by Firestorm »
I take it this transformer doesn't have a center tap.
Kagliostro
Whith branch I didn't mean the branch of a winding with CT
I mean
a branch with standard bridge rectifier
and
a branch with doubler (with the additional switch)
bot branch connected to the same winding
K
ampfab
Post by ampfab »
This transformer does not have a center tap.
I plan on mocking-up this power supply and power amp.
What rectifier part number would you guys suggest?? hoping to have a B+ of 425-500v. maybe build the bridge rectifier from 1n4007s.
i'll let you know how it goes.
thanks for all the thoughts.
Congress Park Amps
