The amp is a bit of a mutt. Original transformers are gone, but they were replaced many moons ago with a 125P1A PT (Harvard/Brown Princeton), and a 125A10B OT (blackface Princeton Reverb). The electronic components on the board were mostly original, except for the filter caps... they were replaced with some Sprague's sometime during the disco era.
It was playing when I got it, but just barely. Had some bad filter hum, so I replaced the filter caps and B+ dropping resistors. Definitely cleaned up the hum, but it's still not a good sounding amp. For starters- it is very quiet. About 1/2 the volume of my SF Princeton Reverb, for comparison. It also has zero clean headroom; it goes from off to distorted.
My main question today is about the power supply. To reiterate, the filter caps and dropping resistors were just replaced. Here are the voltages I measured, and what they're supposed to be per the 5B3 schematic/layout:
B1+ = 361V (350V)
B2+ = 302V (280V)
B3+ = 283V (250V)
There's only an 11V difference between measured and desired for B1, but the difference gets bigger with B2 (22V) and B3 (33V). Any idea what's going on here?
All the downstream voltages are wacky too, but I'm sure I need to replace a lot of bad resistors and caps- almost all of which are original.
Finally- how do you post pics on this forum? Thanks in advance
