Input caps.
utervo
Input caps.
Post by utervo »
Very few guitar amps seem to have input caps like in hifi tube amps. I understand in hifi amps it is used to block DC from input source to grid.
Are any of you using input caps to prevent DC to get to guitar in case of a plate to grid short? Has anyone of you ever had (or heard) a plate to grid short and gotten zapped?
Re: Input caps.
Not me. Note also that the reissue amps currently on the market don't have them either. If there was any danger there I'd bet that the regulatory agencies would have required them.
Re: Input caps.
I use them while I am messing with sasquatch sized plate resistors.
:oops:
It tickles!
es345
Re: Input caps.
Post by es345 »
Input cap don't hurt. It might prevent DC input to the grid in case of a faulty pedal.
look also here http://music-electronics-forum.com/t31678/
Re: Input caps.
I run a 15pf cap from the grid of the first stage to ground on my 100w D clone.
Not sure I can tell it's there but I figure it should shunt any radio interference.
ChrisM
Re: Input caps.
Post by ChrisM »
Tom I believe the OP is refering to a large cap in series with the grid (so from input jack to grid).
It's not a bad idea but as mentioned probably not needed.
It is needed however is your amp has power scaling (VVR, VRM, etc.) as when the control is set low you will get some DC on the grid. Don't want that voltage going back to your fancy pickups.
utervo
Re: Input caps.
Post by utervo »
Yes I meant a bigger cap in series with grid. So the signal goes through the cap which will block DC in case B+ goes to grid for some freaky reason. What would be a proper size, 1uf?
ChrisM
Re: Input caps.
Post by ChrisM »
0.1uF is fine
With the grid leak resistors we usually use it forms a high pass filter well below our audible range.
Re: Input caps.
I just had this problem with my recent "Twenty" build. Brand new JJ 12ax7, and I was hearing a scratchy Volume pot on my guitar. I measured 0.1vdc. Swapped tubes; found a small handful that allowed DC to pass, some that did not. Weird.
Cliff Schecht
Re: Input caps.
Post by Cliff Schecht »
Old Gibson amps sometimes have this. I've done it on some amps for friends where god only knows what is going to get plugged in. For my personal amps I don't bother usually but it's not a bad idea if many people will use the amp.
Cliff Schecht - Circuit P.I.
brewdude
Re: Input caps.
Post by brewdude »
The input cap can be useful when scaling the entire amp's voltages with a VVR.
printer2
Re: Input caps.
Post by printer2 »
Cliff Schecht wrote:Old Gibson amps sometimes have this. I've done it on some amps for friends where god only knows what is going to get plugged in. For my personal amps I don't bother usually but it's not a bad idea if many people will use the amp.
If the amp has a grid leak input stage it needs a cap otherwise the input does not get biased properly.
Cliff Schecht
Re: Input caps.
Ahh yes, this is definitely true and great point. You won't (shouldn't) find a grid-leaked amp without a DC blocking cap. Typically the value is not 0.1uF like stated above though, 0.02uF is what I always see.
utervo
Re: Input caps.
Post by utervo »
So it has to be before (viewing from where signal comes) the grid load resistor, 1M in case of typical 12AX7 input stage, so the grid stoppers are in before the cap?
Super_Reverb
Re: Input caps.
Post by Super_Reverb »
utervo wrote:So it has to be before (viewing from where signal comes) the grid load resistor, 1M in case of typical 12AX7 input stage, so the grid stoppers are in before the cap?
That's right. For a cathode bias input stage, input jack is connected to first grid through a coupling cap. Typical value 1M resistor is placed from grid to cathode, so that the cathode can "see" the grid. This is part of cathode biasing requirement.
Similarly, when you AC couple from plate of one stage to grid of next gain stage, a grid-cathode resistor is required.
rob
