Strange Cathode Voltage - Preamp AC30
MarshallPlexi
Post by MarshallPlexi »
Working on an AC30 clone and for some reason on V1 paralleled and V2 the cathode voltage is only .9 or 1V. For a 220k plate resistor (supply of 300) I'm used to seeing around 1.5-1.6VDC. Any ideas what could be causing that? I tried swapping tubes to see if that could be the cause but no luck. Am I right to think that I'm not getting as much of the amp as I could?
Firestorm
Re: Strange Cathode Voltage - Preamp AC30
Post by Firestorm »
The tube decides how much current it wants to conduct. Some tubes (tired ones) not so much. You said paralleled: how so?
Richie
Post by Richie »
Also depends on the cathode resistor value. If the cathodes are tied together, your probably using like an 820ohm resistor.
if the supply voltage is also a bit low, .9v to 1v sounds about normal.
chief mushroom cloud
Post by chief mushroom cloud »
if it is a dead ringer ac30/6 preamp, the common cathode resistor should be a 1.5k
try another tube.....and check to make sure the 220k is actually 220k (measure it)
Don't overthink it. Just drink it.
