Pulled v1. Put put put put
Pulled v2. Put put put put
Pulled PI. No put put put put.
Layout is here: http://home.comcast.net/~mamp17/index.html
It's the BB layout and is that exact layout from the bias section of the board all the way back to the tone stack EXCEPT the 10k dropping string has an 8.2k at the bottom.
The choke is connected AT that end of the string. (The alt)
Grounds confirmed all around. Passes no signal but I think the jack I installed is bad. Physically doesn't like a plug. 470R in PI, checked not 470k as I have seen before
I have never had a boat. I'm going fishing.
