Jeff (10thtx) has done some great work using these as PI/Power tubes.
I found a couple of posts from Gingertube who had used them successfully as a reverb driver, and I recently came across this article:
http://www.channelroadamps.com/articles/reverb_driver/
Which uses a different pentode/triode with good results (check the clip at the end) using a 600R tank.
I've also heard that an Australian amp mfg 'Maton' used this tube as well as a reverb driver.
Does anyone have any info/schematics/advice on using this as a reverb driver?
I'm trying to come up with something to drive a 300R tank that was in a small combo that I gutted to rebuild as a half power Reverb Rocket for my daughter using the SMPS from another thread. It originally used a solid state driver, but I'd like to keep everything tubular.
The tank was probably the nicest part from the combo (Electar 30R). It's a made in the US Accutronics (8DB2C1B).
