I think I flubbed my head/speaker cabs
B
Post by B »
I planned on covering in tolex, and using Fender style metal corners on my cabinets, But I just realized in all my infinite wisdom, I used a 3/4" round-over instead of a 1/2". :(
How screwed am I? :oops:
~Chris
Re: I think I flubbed my head/speaker cabs
I don't see any issue other than the corner piece might gap a little.
mhartman
Post by mhartman »
I think you pound them a bit to fit any way, so you should be fine. That being said, Taylor (Amplified Nation) will know the answer.
Kazooman
Been There, Done That
Post by Kazooman »
I had the exact same problem. I have only built one speaker cab, but I am a woodworker in addition to having an interest in music electronics. I actually own a 1961 Fender Bandmaster speaker cabinet (blond tolex, maroon grille cloth, 12" speaker with tone ring).
BTW.... I also own the head!!!!!
At any rate, I measured all of the details from my cabinet and was building a clone. I purchased the corner hardware from a major reputable supplier that advertised "Vintage Fender Corner Guards" and went at it. It was only after I had done the woodwork that I realized that the definition of the radius on the corner guards was bogus.
Too late for me. You can go larger on the radius, but not smaller. I had to try to get the corner guards to fit as well as I could, but they are not "perfect" whereas, the rest of my wood work IS "prefect".
Bottom line...... purchase the hardware first and then measure it yourself.
Gaz
Post by Gaz »
You could just be a badass, and do a super tidy job with the tolexing. No need for corner pieces, just don't bang it into anything.
I bought some nickel corners, two recessed screws, lip for inside corner for my Ceriatone head cab I was gifted and I had to take a hammer to them to get them to lay down right.
Glad to hear the hammer is a common adjustment tool for them. :lol:
Just be sure to "adjust" them before you install the screws.
Cygnus X1
Post by Cygnus X1 »
I use bar clamps to gently squeeze them to the radius of the cab, then fasten in place while clamped.
I do a pretty good finger joint, but my corners come out HAD style.
I have to use eight for each cab!
:twisted:
B
Post by B »
Thanks for all the insight guys. I think I'll just forge ahead and remember to bring my BIG hammer when it comes time to finish up the hardware. :lol:
~Chris
alvarezh
Post by alvarezh »
My $0.02
Make a finger joined corner with two small boards, radius it with your 3/4" bit. Tolex it and use it as a test jig. If you manage to rubber mallet them to shape, go for it, if you can't, I would go with GAZ's suggestion.
It's more work, but at least you can't ruin your cabinet trying to shape them on it.
There is a sticky tolexing video tutorial courtesy of our friend Taylor of AmplifiedNation on top of this section, check out his 45 degree corner work.
All the best.
Horacio
Play in tune and B#!
