Cleaning 9 pin tube sockets (duh)
patrick620
Re: Cleaning 9 pin tube sockets (duh)
This came up recently on another bb, and one of the members suggested that it might not be the best way to clean sockets. The metal contacts are likely to be plated to prevent corrosion, and using a guitar string might scrape more plating off. The result is a short term improvement but more exposed base metal and more problems later on. I tend to agree. Applying contact cleaner such as Deoxit on the tube pins and inserting and removing them several times seems like a better solution, and may afford some protection against future problems.
patrick620
Makes sense.martin manning wrote:This came up recently on another bb, and one of the members suggested that it might not be the best way to clean sockets. The metal contacts are likely to be plated to prevent corrosion, and using a guitar string might scrape more plating off. The result is a short term improvement but more exposed base metal and more problems later on. I tend to agree. Applying contact cleaner such as Deoxit on the tube pins and inserting and removing them several times seems like a better solution, and may afford some protection against future problems.
I've used pipe cleaners with DeOxit sprayed on them but the old standby is to just use a tube wiping off the residue when done.
patrick620
Yes. I just thought I was maybe onto something, lol.Structo wrote:I've used pipe cleaners with DeOxit sprayed on them but the old standby is to just use a tube wiping off the residue when done.
