Reeltarded wrote:
I would rather shave my legs with broken bottles than work on another PCB Fender or similar amp.
Amen. Fender PCBs have undersized parts, inadequate traces, and are just plain cheaply executed.
I admire the repairman/builder that was on ebay who took re-issue tube amps out the PCB's cheap E-caps, signal caps, and rebuilt the amp with a circuit card, equivalent vintage caps, E-caps and resistors and built the amp better to BF standards the way Fender electric instruments used too. Even the CBS Silver Face amps by and large are superior to Fenders cheapo non custom shop stuff.
I had a repair, a red knob amp, that out of frustration of the parts and PCB board, I rebuilt as point to point wired amp at a financial loss; they couldn't believe the difference.
As to Cliff's comments:
I usually explain that unless the SS guitar amp has some collectors value to it, it isn't worth their money or my aggravation.
The majority of SS amps are beginner amps which quite frankly would be better utilized as land fill material (this stuff comes under electronic waste) and it would be cheaper to buy something from MF or GC and they would have a warranty or replacement options.
Although not cheap, I feel the same way about Line Six amps.
I don't see any forums or websites dedicated to building new SS amps by some metal player or pedal steel guitar players. Maybe I don't look that hard for them either.
You might find some people building SS or hybrid amps in Hi-Fi.
Put me in the I don't work on SS or PCB amps with a few exceptions.
Ampeg made some early PCB amps and so did Selmer tube amps,
Ampeg made some very good SS amps heads. 1960's
USVox/Thomas organ made some amps that sound good enough if full of cheap parts and transistors (many no longer produced) and have some value from Beatlesque/Vox vibe.
The UK Vox transistor amps are quite good and fetch some good money (the ones the Beatles recorded with) and funnily enough the Fender PA system used and seen in the Beatles last public Rooftop performance gather good money.
I will only work on these since there is some value and the owners won't die of shock when I quote them an estimate.
Best Regards,
Steve
PS Actually, from time to time someone comes with their beloved (70/80/90s) old SS stereo amp or component with either the right or left channel blown and expect miracles more frequently than naught. From time to time, I am half tempted, but you can't hope to meet someone's nostalgic memories as to how it used to sound.
After rebuilding with quality components, improved or discrete discrete equivalents to equal some audiophile equipment, the owner is disappointed it doesn't sound as he remember it.
For those individuals I suggest trying to find a working component or old SS Stereo on ebay.
