where can I have eyelet boards made?
pula58
Post by pula58 »
I need to make a number of circuit boards (each board is the same) for some amp builds. I'll be using eyelets and would like to have the boards pre-drilled with eyelets installed.
I could provide a to-scale PDF woth the hole locations, or other suitable file (DXF).
Any leads on this?
Thanks!
P.
tubeswell
Re: where can I have eyelet boards made?
Post by tubeswell »
Hoffman board kits with eyelets
http://www.hoffmanamps.com/MyStore/perl ... D=!ORDERID!
There's a link for 'design your own board'
http://www.hoffmanamps.com/php/TurretBo ... tBoard.php
pula58
Post by pula58 »
tubeswell wrote:Hoffman board kits with eyelets
thanks for the info!
But...the board I want to have made is custom, so, the pre-made hoffman boards wouldn't be the right thing. And the "design your own board" is a great thing, but the holes are 3/32, too large for eyelets (I have already asked Doug H about this).
tubeswell
Post by tubeswell »
What about Watts?
http://www.turretboards.com/circuit_boa ... _index.htm
Or Mojo?
http://www.mojotone.com/amp-parts/Fiberboards
(You'll have to DIY them from the parts)
pula58
Post by pula58 »
I am hoping to avoid DIY. What I'd like to do is design the board using DIY, then, transfer the design to a CAD tool, and then be able to give someone a file and have them build the boards. This way I ca ncrank out a number of amps without having to make the boards from scratch all the time.
Milkmansound
Post by Milkmansound »
I can not recommend Watts enough - they make beautiful boards. Its very affordable. Their turrets are awesome too!
Definitely worth a little extra money for what they do.
Also, I recommend garolite and turrets over fiber and eyelets. Just my 2 cents.
wsaraceni
Post by wsaraceni »
did you try turretboards.com? just email him and ask him if he'd make you up some boards. he does custom chassis work. maybe custom board work would be done too.
Prairie Dawg
Post by Prairie Dawg »
If you're talking about making eyelet boards out of vulcanized fiberboard ala Fender it's ridiculously easy to do. I've built a dozen or so of them and I don't know much of anything.
If you believe in coincidence you're not looking close enough-Joe leaphorn
pula58
Post by pula58 »
wsaraceni wrote:did you try turretboards.com? just email him and ask him if he'd make you up some boards. he does custom chassis work. maybe custom board work would be done too.
Thanks for the tip!
I called there, talked to Ken...sounds promising!
P.
Milkmansound
turretboards is Watts, for the record. Ken is awesome. Do it!
fusionbear
Post by fusionbear »
Milkmansound wrote:turretboards is Watts, for the record. Ken is awesome. Do it!
I agree. I only by my boards from him now.
Learning to learn...
patrick620
Post by patrick620 »
At some point you might try making a template out of sheet metal. Just clamp and drill.
[IMG:800:600]http://i28.photobucket.com/albums/c202/ ... 20/003.jpg[/img]
Where can I have eyelet boards made?
I see that Weber has this service available.
Prairie Dawg
I did a blog entry that details the entire process. Easier than I thought possible. If I want to make a board it takes me about fifteen minutes to a half hour to knock one out.
http://judyboxamp.blogspot.com/2012/03/ ... board.html
We have 6 5E3 chassis so the guys wanted to build two amps. Had a turret board so I cut, marked, drilled and installed short turrets yesterday. It was fast and easy.
The original turret board I started with had very small turrets so I had to use a piece of wire chucked into my drill to run down the turret holes to mark all the turret locations on the new boards. Worked like a champ.
