are there any dpdt or even spst style relays on the market that i could power using my filament supply?
available 6v dpdt relays?
Re: available 6v dpdt relays?
In the past I have used an Omron G5V-2-DC6 when powering from 6.3V filament taps. Unreguated you should get around 8.8-9.2VDC and when the coil is activated the voltage at the coil will drop.
TM
TM
diagrammatiks
look at the sub miniature relays.
those come in 3 and 5v versions regularly.
I have 5 Vdc in stock both SPDT and DPDT
http://www.omron.com/ecb/products/pry/111/g5v_1.html
I'm reducing my price on these SPDT to .79ea
Also have the Omron and NAIS/Aromat DPDT at $1.50ea
Steve
Steve
Prairie Dawg
To figure out what you need or want it's a good idea to take a tour through the Mouser catalog. I just got done figuring out an equivalent relay for a switching relay in a Peavey Valve king. It was a bit of work but I learned quite a bit about these things. Coil resistance, voltage, footprint, hold voltage, release voltage and so on. Prolly need a diode bridge there too.
If you believe in coincidence you're not looking close enough-Joe leaphorn
The 5V DPDT relays I have are:
Omron G6A 234P ST US 5Vdc
Aromat DS2E-S- 5Vdc
Also have 12V in the Omron G5V-2- 12Vdc
All 3 at $1.50each
Aromat DS2E-S- 5Vdc
All 3 at $1.50each
