Ceriatone Prinzetone Tranny Recommendations
milkyBK370
Post by milkyBK370 »
Hi folks. I decided that my next build should be Ceriatone's Prinzetone. I really like the sound of it (based on some clips I've seen/heard) and the general consensus is it's a great little amp. Like my previous build I'll just be getting the chassis from Ceriatone. The rest I can source elsewhere. I have a bill of materials almost complete but need some help choosing a decent PT.
I notice that Ceriatone use their 5E3 OT in the Prinzetone as well. I have used Hammond trannies in the past and have been pleased with the results there. Still, I'm open to any suggestions you might have.
Here's a link to the Ceriatone product page..
http://ceriatone.com/productSubPages/Pr ... neMain.htm
And the layout I'll be using...
http://ceriatone.com/images/layoutPic/f ... iatone.jpg
I'm particularly interested in trannies that are readily available in the UK.
Hope you're all well.
Badside
Re: Ceriatone Prinzetone Tranny Recommendations
Post by Badside »
The Princeton uses a 8000ohm primary while most 5E3s use a 6600ohm
The Hammond 5E3 replacement is the 1750H (1760 if you want multiple output impedance taps)
Or you can get the 1750/1760E if you want a "true" Princeton 8000ohm primary.
I know some manufacturers make OTs with a 6600 and a 8800 primary tap. Might be fun for experimenting, though I'd stick with a "clone" of the original OT like the Hammonds if it were me.
Amplifiers built:
Marshall 2204 head with some mods
Low-power 2204 (cathode biased 6V6s)
Single-knob dual-6K6GT amps using a Wattkins uPCB
AC30 clone with Plexified preamp section
AX84 Firefly
