Using the tools: autoranging multitesters are finicky
I have noticed some of my resistors, oddly just old stuff, measures in fractions of a meg (decimalized M ohm), where the newer resistors of the same values generally just right to the k ohm scale.
It's annoying, and not much more. Just wanted to see if anyone had an idea of why these parts are seen differently to the machine.
Milkmansound
Re: Using the tools: autoranging multitesters are finicky
Post by Milkmansound »
I usually hit the leads of old resistors with a little steel wool before measuring them and installing them. It takes off the surface layer of oxidation which can affect the reading.
What Milkman said and what brand of meter is in play here?
Most of these are tested as I pull them out of old amps, I hadn't considered cleaning them making a difference, generally fresh flowed solder there.
Both a Sperry and an RS pos do it. Just wondering if they know something I don't. :)
Clips or just probe ends? If find clips are essential to a stable readout.
