Ok folks, i,m building up a 36 watt marshall style build based around the tmb circuits, essencialy i am aiming to access the two channels vis a foot switch and add a tone stack to the clean channel in place of the tone control, i reckon i should be able to just clone the drive channels tone stack and insert after the clean gain pot, this brings me on to the second part of the build which is channel switching, again pease correct me if i,m going about this the wrong way but effectivly i,m aiming to use a small relay to swap channels with the unused channel being shorted to earth, its similar to the dumble elay circuit but i,m slightly concerned about gettin a audible click as the relay swaps channels.
i,ll post some pics when i get a chance of the chassis and the now installed TDC power transformer
Any advice will be much appretiated
