What to do
jestaudio
What to do
Post by jestaudio »
I,ve got a working Laney chassis with 4 el84s , a 30 watt output trannie and a toroidal mains tranny that belts out about 330 rectified 220 unrectified, loads of usefull parts,
I need a bit of inspiration on where to tacke it, el 84,s sugeest something with a marshall taste but is the trannie man enough for the job :)
All suggestions gratefully recieved
Re: What to do
Well you could build a 18 watt style amp accept use the 4 x EL84 output.
Be aware you need to use a different output transformer but the one that came with the Laney might work.
Gaz
Re: What to do
Post by Gaz »
Why a different OT?
Re: What to do
Isn't that Laney already a Marshall based circuit?
If it works I would just concentrate on changing up the circuit to your liking.
jestaudio
Re: What to do
Post by jestaudio »
M Fowler wrote:Isn't that Laney already a Marshall based circuit?
its a bit of a winter project, stacks of corrosion on the board, scratchy pots etc(it had been stored in a garage) and in fairness it may be based on a marshall but it sounds like crud, even through my rcf powered cab which makes anything sound good :D
Re: What to do
There is a 36W design based on the Marshall 18W. If you aren't a member of the 18W forum, I can find the schematic for you. Rip out what's there, keep what's useful. Build another amp in it's place. If you have a good chassis and iron, you are more than half way there in terms of cost. IMO, it's just begging for the 36W, which is a 4x EL84 design.
Zippy
Re: What to do
Post by Zippy »
You might also check out the TrainWreck "Liverpool" or "Rocket" options - see the TrainWreck subforum for schematics and layouts.
Luthierwnc
Re: What to do
Post by Luthierwnc »
Best of both -- look at the Matchless DC30 and use the bottom half of the inverter. sh
