1 watt tube amp
1 watt tube amp
I want to build a 1 watt tube amp using a 12AU7 for a power tube and a 12AX7 for the preamp. Does anyone know of any transformers that would work for this application?
- Jack Hester
Re: 1 watt tube amp
Do you have a schematic? What kind of B+ voltages are you looking for? SS rectifier or tube?
Jack
Jack
Re: 1 watt tube amp
Here is something posted a few years ago.
Re: 1 watt tube amp
For single ended you can use a reverb driver (one with an 8 ohm secondary).
Mojo has this one for push-pull:
http://www.mojotone.com/amp-parts/trans ... -PP-Output
Re: 1 watt tube amp
http://acepepper.com/ThunderTweakWeb/in ... ter_v4.pdf
This looks good, although I haven't built it myself yet.
It uses a fender reverb tranny.
power transformer
I am ok with the reverb transformer for the output, but I would like to use a smaller transformer other than the Hammond type. I believe I can get by with a 350V rail voltage after rectifier and 1.2 a for the heater. Maybe 15-20VA. I am working on a schematic now. Thanks for all the great info!
Voltage doubler circuit
Here is a transformer option, but need to use voltage doubler to obtain desired voltage. Hammond 262E6 18VA 120V secondary @ 87ma. 1.2A for heaters.
Re: 1 watt tube amp
I built a Firefly:
https://tubeamparchive.com/viewtopic.php?t=11248
Very cool project, and good sounding amp.
1 watt schematic with voltage doubler
Here is my proposed schematic for a small simple 1 watt design. My understanding of the voltage doubler is as shown. 120VAC X 2.8 = 336VDC. Is there an easier way to achieve the same results? Are the component choices ok?
- renshen1957
Re: 1 watt tube amp
Hi,rdjones wrote:For single ended you can use a reverb driver (one with an 8 ohm secondary).
A self-split 12A_7 design such as the Firefly was posted at the AX84 website.
I would suggest the Hammond 125 A push pull amp. Loads of options as to the primary/secondary, and I believe it runs about $33.00 from ebay.com or from Angela.
http://angela.com/hammonduniversalsingl ... rmers.aspx
Another option would be at Edcorusa.com
Their 10k primary 10Watt amp (yes, I know it is way over the 1W) is $17.22
http://www.edcorusa.com/products/354-xpp10-8-10k.aspx
Best Regards,
Steve
Cliff Schecht
Re: 1 watt tube amp
Anybody here played with using 70V line transformers as output transformers? For a 1W application there should be no problem finding a CHEAP 70V distributed line system transformer. I have a few but have never played with this myself. I know that the right ratio for a tube output stage can be achieved with one but they aren't meant to handle static DC (SE amp). But at the same time, a 10W line transformer will have no problem handling the static DC from a 1W output stage..
Cliff Schecht - Circuit P.I.
Re: 1 watt tube amp
A full wave voltage doubler looks like the attached pic. If you want 100uF total for the first filter, make each of the two caps 100uF.
Re: 1 watt tube amp
Re-drawn voltage doubler. This will cut my amperage in half, but still should have enough power only 2 tubes- 12AX7 and 12AT7. My secondary is 120VAC. With this configuration what will my plate voltage be?
Re: 1 watt tube amp
Without knowing the series resistances of the PT, I'd guess about 310.9VOLT1967 wrote:Re-drawn voltage doubler. This will cut my amperage in half, but still should have enough power only 2 tubes- 12AX7 and 12AT7. My secondary is 120VAC. With this configuration what will my plate voltage be?
