RESTORING ORANGE
jujudubluz
RESTORING ORANGE
Post by jujudubluz »
Hey guys,
i'm replacing all the electrolytics on my old Orange OR120M and can't find a 32µF@450v. Sprague or CDE only come in 30 or 40µF
is it safe to replace it with a 30µF or 40µF? How will it affect the tone?
Let me know.
Juju
"less is more" mies van der rohe
greekie
Re: RESTORING ORANGE
Post by greekie »
Both will probably be fine, but just to be "correct" take the 30uF, unless it's crazy expensive compared to the 40uF kind.
Normally caps go from -20% /+50%, so a 40uF can be 32uF, a 30uF can be 45uF, etc.
Jake
selloutrr
Post by selloutrr »
F&T make a 32uf but as said both 30uf and 40uf will work just fine. keep in mind the capacitors are not exactly on spec they have a plus or minus of 10-20% depending on brand.
Most important is making sure the cap fits in the original spot.
Best of luck the Vintage Oranges are great amps! :D
My Daughter Build Stone Henge
Both www.Triodestore.com and www.tubesandmore.com have 33uf/450 axial caps you can use.
For can caps I recently used 32/32-500v caps in my Retro 50 clone.
jujudubluz
thanks a lot guys,
i'll post pics when it will be done, it was in an awful shape, i already retolexed it and a friend of mine will make me brand new roll bars which were missing too...
thanx again
tubesinside
Post by tubesinside »
Did one myself recently...needed a lot more work though..
I installed the 'Master' volume as in the OD version but with the 1972 PI.
I used JJ Electronics 250uF 500v caps and fitted 220K 2 Watt bleeders.
Amp sounds great. Look here [http://forum.orangeamps.com/viewtopic.p ... &view=next]
No gain...no pain!
jujudubluz
looks great,
where did you got those rollbar handles?
mine were missing so i'm getting a few made by a friend of mine.
Juju
tubesinside
Got them from RS Components...but they are not exactly the same size as the originals....remember I have a custom faceplate.
Sorry, should have also said that I used the F&T caps on the PCB. Got them from Tube Town.
No gain...no pain!
