Best Neutral RTV Goop?
- David Root
What do you all use? I need something to hold some heavy caps in place.
- FUCHSAUDIO
Re: Best Neutral RTV Goop?
GE Silicon sealer and household glue is excellent. Home Depot has it in clear or white. I also use (don't laugh) Liquid Nails. They sell a toothpaste sized tube of clear Liquid Nails that is seriously strong shit.
- David Root
Thank you very much! I take it the Liquid Nails should not touch anything but the caps?
- FUCHSAUDIO
Unless you want it to hold down other things....
amplifiednation
hahaha, well put.
Liquid nails will hold wood to a concrete floor...forever.
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
If you use caulking be sure it doesn't contain acetic acid.
- David Root
Tom that's why I put the word "neutral", meaning not acidic, in my subject line. I did read that thread, pretty scary stuff.
- FUCHSAUDIO
Also avoid latex based, as it does have water/moisture content that can migrate. The current GE silicones (The one I have here is labeled Premium Waterproof Silicone window, door, attic, basement) is pretty goods, no outgassing and holds things solid.
David,
I work for a very high tech company, may I suggest Momentive Adhesive (Formerly GE) RTV 5818 which we use it for all of our pcb applications.
http://www.mgchemicals.com/products/5818.html
It's not cheap though...
Hey John,John_P_WI wrote:I work for a very high tech company...
I'm familiar with "high tech" - I might even work for one myself.
What makes a company "very high tech"?
Ha good one Zippy, you got me on semantics here.
How about an industry leading medical diagnostic equipment company? At least it sounds "very" high tech....
On a recent rebuild I used black automotive weatherstripping adhesive.
rd
rd
- David Root
John, that is an interesting spec on that 5818. Marine grade, even. In a 300ml container I'm afraid that most of it would set up before I used it all.
At $17 in Canada that is 8x any caulk I've used before, but to be fair that was el cheepo bathroom caulk.
If I could get something close in a smaller tube that would be better.
Crap. I've been using DAP 100% Silicone that 'has' acetic acid, or gives it off as it cures. I just assumed it was okay because it was 100%. Looks like the stuff Fuch recommend has it too though...Structo wrote:If you use caulking be sure it doesn't contain acetic acid.
More specifically, I've been using a dollop on the bottom of radial electrolytics to secure them down to a garolite turret board. Does anyone think the silicone touching the leads will actually corrode them?
