Peavey Triumph 60 Master Volume add
skynyrd
Post by skynyrd »
What would be the best way to add a master volume to a peavey triumph 60 ? It has 2 6L6 power tubes, 4 12ax7`s and 1 12at7, I have a schematic if anyone needs it. I do appreciate the help.
Re: Peavey Triumph 60 Master Volume add
I'd do a Lar-Mar PPIMV. As it happens I just posted a schematic here: https://tubeamparchive.com/viewtopic.ph ... highlight=
Should work fine with your amp.
If you don't mind the Marshall-style knob, MetroAmp sells a kit for $10 (no afilliation, just pointing out a one-stop source).
