Check out the chassis I designed.
				Joost
- Location: The Netherlands or Holland. Whichever you prefer
I am kinda stoked! Here is the chassis I spent many an evening designing. Getting each hole right. It's 3 mm gauge aluminium which is about 1/8" thickness. The chassis is 19.5" x 8.625" x 2.5" for a Dumble/Two Rock hybrid build.
Let me know what you think. It'll get powder-coated early next week!
[img:900:600]http://www.familieassink.com/documents/chassis1.jpg[/img][img:900:600]http://www.familieassink.com/documents/chassis3.jpg[/img]
[img:900:600]http://www.familieassink.com/documents/chassis2.jpg[/img]
						Re: Check out the chassis I designed.
That looks great!
What program did you design it in?
Nice!
How did you cut the openings?
Are you sure you don't mean 3/16" thick?
way too nice to powder coat!
						- Reeltarded
Nice...
Is powder coating a good idea? Naked metal seems to be for a reason.
No issues with it.Reeltarded wrote:Nice...
Just tape off your ground points.
Nice looking chassis.  3 mm is less than 1/8" or 0.118" to be exact.
				Joost
*ahem* I used illustrator to draw exactly to scale. I can send the PDF to an acquaintance who has a water jet machine which can read PDF files and he cut the aluminum sheet.
I will NOT be powdercoating the inside. Just the outside!
I think I meant 1/8"
				Drumslinger
very nice Joost!  Is Illustrator easy to use?
				Joost
Yes very! And it's very accurate.Drumslinger wrote:very nice Joost! Is Illustrator easy to use?
Very nice!  That would probably look great polished up as well.
									If you can't be a good example, then you'll just have to be a horrible warning.
You have very useful friends!Joost wrote:I can send the PDF to an acquaintance who has a water cutting machine which can read PDF files and he cut the aluminum sheet.
- Milkmansound
when you powder coat, you want to make sure the holes are just a tiny bit bigger than they are supposed to be, because the powder actually adds a little thickness. If you file them back out, you can chip the paint by accident.
Wiggle room when powder coating is a good thing!
				Joost
Thanks for the tip milkman!
Man those holes look great. I should make a few calls around here and get a jobshop to waterjet and bend my stuff up. This unibit drilling is for the birds...that chassis looks perfect!
