1M Reverse Audio Pot
brewdude
Post by brewdude »
Does anyone know where to buy a 1MRA pot?
I want to try a Matchless Chieftain style pre-amp/tone stack.
Andy Le Blanc
Re: 1M Reverse Audio Pot
Post by Andy Le Blanc »
Use a Mfg. link from a product page from say Mouser, see if their in somebodies
line card, you might be faced with a minimum order, or you might have to ask.
Which product did matchless use?
lazymaryamps
jmohr58
Post by jmohr58 »
I am not sure about a 1MRA pot, but Tube Depot has a 3MRA pot and if my math is correct
R=((R1XR2)/(R1+R2))
1E6=((3E6X1.5E6)/(3E6+1.5E6))
Than adding a 1.5M resistor in parallel with a 3M pot shoud give you a 1MRA pot.
http://www.tubedepot.com/r-cts-a.html
This is a CTS for $3.95
So if you can't find a just a 1MRA, this is an alternative.
Hope this helps.
Jerry
brewdude
Post by brewdude »
Thanks for the suggestions.
jmohr58
Post by jmohr58 »
No problem,
Looked at about 15 different amp part websites and the CTS 3MRA was the only reverse above a 50k I could find. The only reverse I found at Mousers website is a PCB mount minature on web catalog page 725 sytle H. But they do have it in a 1M values. I don't think you have to order quantaties, but you would have to check.
http://www.mouser.com/catalogviewer.asp ... atalog=643
At Tube Depot you can order by peice and shipping is $4.95 FedEx ground for under $99
They also have the 1.5M resistor in 1 Watt Carbon or 1/2 Watt Metal Film Precision. http://www.tubedepot.com/resistors.html
Jerry
Deric
Post by Deric »
Smallbear has them in the smaller 16mm pot.
http://www.smallbearelec.com/Detail.bok?no=116
Deric®
jmohr58
Post by jmohr58 »
Thanks Deric,
I can add another site to source parts.
Jerry
brewdude
Post by brewdude »
Thans again for all the help.
I tend to avoid the smaller pots like the one at Small Bear. So, at this point I am leaning towards the 3MRA from AES with a 1M5 strapped across the pot.
Will this change the taper?
Also, this pot is utilized as a variable resistor controlling bass within the Chieftain circuit. Will this be an issue?
Deric
Post by Deric »
Unfortunately, yes.
Deric®
Kagliostro
Post by Kagliostro »
brewdude
Post by brewdude »
Thanks for the link.
O.K., if I understand "The Secret Life of Pots" correctly, a linear pot can be converted into a reverse audio voltage divider. Mouser sells a 5M linear pot by Alpha. If a strap 1.25M of resistance across to the wiper I should end up with a total pot resistance of 1M with a reverse audio taper yielding about 85% resistance at 50% rotation .
Am I correct?
Kagliostro
Try it with a pot and a resistor you have and measure the results
you'll find that you can obtain a very nice log pot from a linear one
Commercial log pots often has two sometime three different portion of resistive material and what you obtain is near to a log pot
see here
http://sound.westhost.com/pots.htm
and, yes a 5M + 1.25M will give you a 1M pot
Kagliostro
brewdude
Post by brewdude »
Thanks for the link. It is quite informative.
My plan is to get a 5M linear pot with my next Mouser order, and experiment with strapping different resistor values from 750k to 1.5M and see what works best for this application.
ApexJr.
Post by ApexJr. »
I have some Allen Bradley house numbered measuring a little
over 1 Meg (1.25M - 1.5M) Reverse Audo RV 4 type pots
for $3.50 each in stock.
Steve @ Apex Jr.
steve.apexjr@prodigy.net
brewdude wrote:Thanks for the link. It is quite informative.
Steve's (Apex Jr.) pot would probably be a better way to go. If you create a "RA" pot with a shunt, the resistance across the element will change with the setting, so you are likely to get some other changes to the circuit that you don't want. In your example using 5M with a 750k shunt, it'll go from 650k to 5M from 0 to 100% rotation.
