Making your own film/foil caps?
coolidge
Post by coolidge »
Has anyone tried making their own film/foil caps? How difficult could it be?
selloutrr
Re: Making your own film/foil caps?
Post by selloutrr »
Difficulty = how accurate do you want them to be?
quality materials (usually not cost effective for a one off or DIY)
clean controlled enviroment ( static and dirt are not a good thing )
My Daughter Build Stone Henge
patrick620
Post by patrick620 »
http://www.ehow.com/how_7786154_diy-mas ... citor.html
Probably not what you had in mind though
ampdork
Post by ampdork »
Once knew a guy from another country who grandfather would roll his own.
Once your good at it you can determine length of paper for specific values....probably the formula is around the net.
So for sure it can be done pretty easily and is probably a lot of fun to mess with.
Someday I would indeed like to build an amp for me that uses resistance wire spools and home rolled caps and as much made from scratch stuff as is possible.
"...& I'm all out of bubblegum"
Tonegeek
Post by Tonegeek »
Pitcher Amplification
http://pitcheramps.com
Lonely Raven
Post by Lonely Raven »
Tonegeek wrote:Might as well go all the way: http://dailymotion.alice.it/video/x3wrz ... riode_tech
That's a lost art right there...
Jack of all Trades,
Master of None
