Ruby tubes 6L6GCM-STR
iknowjohnny
Post by iknowjohnny »
Anyone know who makes this tube? It's about a year or 2 old, so what was Ruby rebranding for 6L6's then? Single small round halo type getter. Heres a pic
http://www.tubesandmore.com/cemirror/in ... -M-STR.GIF
Firestorm
Re: Ruby tubes 6L6GCM-STR
Post by Firestorm »
Looks like Shuguang's work.
iknowjohnny
That would make sense. Seems like they sell a lot of chinese stuff.
iknowjohnny
Yep, no doubt. Well, i wanted to try a pair of the extremely highly regarded SED 6L6, and i just found a pair I can try in my amp. At about $80 they are double what they were getting till they jacked the cost way up. But i don't mind paying that if they are as good as they say. Some say better than many highly regarded NOS 6L6. But i wasn't about to spend that much w/o knowing, and now i can try b4 i buy.
selloutrr
Post by selloutrr »
Ruby uses mostly Chinese tubes.
They are tubes of function not tone.
What makes Ruby tubes worth buying is the 90 day replacement warranty.
My Daughter Build Stone Henge
super100
Post by super100 »
Ruby tubes have a 6-month (180 days) replacement warranty.
http://accessories.musiciansfriend.com/ ... sku=212030
vibratoking
Post by vibratoking »
I have quite a few Winged C 6L6s. I compared them against some TAD 6l6s in a Fuchs ODS50 and an original 65 Super reverb. There is almost no difference in the Fuchs and the Winged Cs are only slightly better than the TADs in the Super, IMO. I would not pay double the $ for them, that's for sure. I did not compare them at different bias points - both were at at about 33mA.
iknowjohnny
vibratoking wrote:I have quite a few Winged C 6L6s. I compared them against some TAD 6l6s in a Fuchs ODS50 and an original 65 Super reverb. There is almost no difference in the Fuchs and the Winged Cs are only slightly better than the TADs in the Super, IMO. I would not pay double the $ for them, that's for sure. I did not compare them at different bias points - both were at at about 33mA.
well, i DID read that to get the good with the SED's you have to bias them reasonably hot. I think they were talking 70%. But 33 is pretty low for a 6L6 unless the plate voltage is stupid high, no?
selloutrr
Post by selloutrr »
super100 wrote:Ruby tubes have a 6-month (180 days) replacement warranty.
They increased it since I last did business with them. maybe it means the tubes are getting more reliable 8)
