I've got a Traynor TS-50. It's marginally functional... some scratchy pots, leaky caps and whatnot.
Sounds as good (ahem... cough, cough...) as you'd expect a 30 year old SS amp to sound.
What is salvageable? Any build suggestions?
Thanks,
Rob
Traynor TS-50. Any ideas?
Music is an expression of the inexpressable ~ Vernon Reid, Musician.
Re: Traynor TS-50. Any ideas?
Chassis, knobs, replace the CB with a fuse holder, switch, AC cord, jacks, maybe the reverb tank
What are the dimensions of the chassis? What size speaker is in the cab? This could be the beginning of a great Grab-N-Go type combo amp. I gut a lot of SS combos and build tube amps in them. What kind of amp do you want or need?
go to ebay - musical instruments - guitars - amplifiers - search "project" or "Mesa PCB" a russian company is selling a tested Mesa Boogie Mark 2 C+ PCB set. you could gut this amp and make a mesa.
- or -
Fix it and sell it and use that money for another amp you want.
- or -
My Daughter Build Stone Henge
It's got a 19 inch chassis. 9.25" three spring accutronic reverb tank.mcrracer wrote:What are the dimensions of the chassis? What size speaker is in the cab? This could be the beginning of a great Grab-N-Go type combo amp. I gut a lot of SS combos and build tube amps in them. What kind of amp do you want or need?
I was considering a one channel, clean- only, ef86, quad el84 combo... Pre- Top-Boost AC30.
Very impressive. That PCB sparked my interest. Is it anyone from the board?selloutrr wrote:go to ebay - musical instruments - guitars - amplifiers - search "project" or "Mesa PCB" a russian company is selling a tested Mesa Boogie Mark 2 C+ PCB set. you could gut this amp and make a mesa.
Thanks,
Rob
You only gave one dimension of the chassis and did not mention the speaker. It would be easy enough if you have the room to build a Rocket in there. EF86 tubes can be microphonic but if you insist there are circuits which incorporate that tube. There are also other octals which are more reliable which could go up front; 6SJ7, comes to mind. 6U8, 6GH8A.
Are you comfortable building point to point or eyelet and turret board assembly? Personally I would ditch the reverb but many guys insist on having it so it could be retained too.
The Chassis is 19" x 8 1/2". 1x12 combo.mcrracer wrote:You only gave one dimension of the chassis and did not mention the speaker.
Saw that the other day, looks great. Thanks.selloutrr wrote:http://cgi.ebay.com/MESA-BOOGIE-MARK-2C ... 1c17ceaeea
I don't believe they are a TAG member.
Rob
