On a typical Rocket what will lowering the value of C2 down to 390pf do.
A
Rocket tweak C2
Re: Rocket tweak C2
Since that is a coupling cap, I would say that reducing the value will cut even more lows that it already does.
As far as coupling caps go, that is a pretty low value to begin with.
What are you trying to do?
just wondering
I was thinking about swapping the ceramic for a silver mica and only had a 390pf on hand, seems as though lowering that value is not a good move.
thanks T
thanks T
Re: Rocket tweak C2
If you want to hear the effect of the change from ceramic to mica, you'll need to closely match the cap value.
Re: Rocket tweak C2
Ange do you have a meter that will measure that low?
Caps rarely measure what they are said to be.
