Faceplate design
paisley_tele
Faceplate design
Post by paisley_tele »
Are there any guys here that are good with adobe illustrator to design faceplates? I can have a local trophy shop make one for me for cheap if I have it designed so all he has to do I run the file.
selloutrr
Re: Faceplate design
Post by selloutrr »
do you have all the dimension and spacing already figured out?
My Daughter Build Stone Henge
teleslinger73
faceplate design
Post by teleslinger73 »
just had a friend do mine, he might do another for a small fee. if interested let me know. he only charged me like 25 bucks and said he'd be interested in doing more designs for me. [/img]
sunnydaze
Post by sunnydaze »
If you have some other software that can you can use to "draw" the faceplate, it can be printed directly to a PDF file using free software called PDF 995. You could design the face plate in Excel for example, and then print the drawing to a PDF file.
http://www.pdf995.com/
I use the licensed version at work all the time. PDF995 shows up as a printer option. So instead of selecting your usual paper printer, simply choose PDF995 and then print as usual and your document will be printed directly to a PDF file.
Hope this helps.
mike
Sunnydaze
