Orange "Dips" ????
dreric
Orange "Dips" ????
Post by dreric »
Does any one know anything about the orange "dips" caps sold by justradios.com?
http://www.justradios.com/capkits.html
I can't get a clear answer from the owner, does anyone know if these are the same as the Mallory PVC6** caps?
Eric
selloutrr
Re: Orange "Dips" ????
Post by selloutrr »
it's possible
specs:
Construction: Highest quality poly film construction. Under 0.01uF are PNN Polypropylene Metal-Foil construction while 0.01uF and above are DME Metalized Polyester. These metalized poly film Orange Dips are made by ISO 9002 & 9001 certified manufacturer / OEM supplier to CDE Cornell-Dubilier, (Cornell-Dubilier), HP, Sony, Canon and Bosch.
Use: Excellent for DC blocking, coupling, filtering and by-pass in tube radios, audio and guitar amps, hi-fi, communications equipment and general electronics. Superior replacement for paper/wax capacitors in tube electronics.
Features: Rated at 630 Volts; Extra long (30mm) copper-ply radial leads; non-inductive construction; good solderability; Compact body size; Orange epoxy dipped for superior heat, moisture and solvent resistance.
http://www.justradios.com/DMEcapacitors.html
My Daughter Build Stone Henge
ToneMerc
Post by ToneMerc »
Coat these in orange epoxy and call them "Dips"
http://www.etr.com.tw/eng/dc_use_film_c ... c01_04.htm
TM
KindaFuzzy
Post by KindaFuzzy »
I'm not sure if they're exactly like the mallory ones or not, but they are much smaller than sprague orange drops or even the yellow mallory caps. I use them all the time, and the yellow tubular caps he sells are excellent and super cheap too. I buy all my coupling caps from him, highly recommended, and try some of the polystyrene's he's got too.
dreric
Post by dreric »
That's good to know. I came across him as being the just about the only vendor I can find selling a 10 x 10 @ 500v can which the Dumble 124 calls for.
RJ sells the Mallory caps, he's got to get them from somewhere!
Eric
ChrisM
Post by ChrisM »
Used them and their other caps and resistors many times, great stuff, good quality.
jelle
Post by jelle »
Website claims they are 225P series. These are good quality polyester caps.
Jelle
Markusv
Post by Markusv »
Use them all the time too
Have used other caps from other vendors too- but this guy is consistent, well priced, helpful , ships fast etc
Like his resistors too
He told me once that the caps are made for (or by) Cornell -Dubilier. Not sure if I understood correctly
He also sells green mylars in bulk and I've tried them- they sound surprizingly good!
Markus V
.........Now where did I put it?
FYL
Post by FYL »
Made by ETR in Taiwan, who also supplies Cornell-Dubilier (and numerous others) on an OEM basis. Same caps, different markings.
