Heatsink info for VVR?
sbolt
Post by sbolt »
Hi, I did a search-does anyone have a reference or part# suitable for a heatsink to be used for the installation of a VVR3 on a 50 watt amp with steel chassis?
thanks in advance
FYL
Re: Heatsink info for VVR?
Post by FYL »
A <3°C/W heatsink should be OK. There are hundreds of different models to choose from, depending on your location, amp chassis, available space, mosfet used, etc.
sbolt
Post by sbolt »
you mean <3 degrees C/W thermal resistance of the heatsink right?
If that is so, then I can see I have a lot of choices,
thanks
FYL
Post by FYL »
Yes. And the lower the better.
sbolt
Post by sbolt »
Thanks!
