I've recently finished a Rocket and have been playing the snot out of it. It has caused me to play around with some tones and sounds that are fairly new to me. One the things that it has done has made me much more aware of the value of a great clean tone.
On that note, I hadn't played my first amp build (a straight up 5e3 clone with the exception of Brown deluxe tone control) in a while so I set it up and AB'd it with the Rocket. I was quickly reminded why I hadn't played the Deluxe in a while..... The boomy, flabby bass. However, set fairly clean, the tone of the 5e3 is nearly on par with the Rocket in a different way. I'm not a big u2 fan, but I instantly realized that a lot of the Edge's clean tone comes from his tweed amps, and not his AC30's.
Sorry for the long lead up, but what I would like to do is tweak my 5e3 so that it is more balanced tonally. I would like to keep its' basic character, but reduce the bass, so that it is not boomy with humbuckers. At the same time I don't want to ruin how it sounds with single coils. Can this be done with out a switching options? I know it will be a compromise, but I'd like to avoid switches if possible.
This is where I'm thinking of starting. I have some .022 uf and .047uf caps on hand, so I'm thinking of swapping .022's for the .1 coupling caps on v1 and v2. I've read on other forums that some people suggest swapping out all four .1uf caps for .047's. Anyway, it will only take a few minutes to swap coupling caps so I think I'll try it and see what happens. I don't think I want to add NFB, but I'd be open to playing with bypass caps and R values. I will need to order some other e-lytic cap values though
