I have a TW-style amp, with a center-tapped heater winding. The center tap is connected to a voltage divider (tapped off the screen B+), giving 70Vdc of elevation (250k/47k resistors, with 100uF/150V cap across bottom (47k) resistor).
Even with this setup, I still get some heater hum amplified by the preamp.
If I want to try a humdinger, should I disconnect the heater center tap entirely, connect the two outside lugs of the humdinger pot across the heater winding, and connect the wiper to the 70V elevation point?
I think that's right, because the humdinger pot is creating a virtual center tap through the wiper, and adjusting the pot balances the 2 (virtual) halves of the winding. But I figured it was better to ask before I create any smoke and fire
