5e3 bright channel problem
telestrat
Post by telestrat »
I need some technical help regarding my tweed deluxe.
The Bright channel (both inputs) has stopped working, no audible sound at all. The normal channel is working fine.
Any Ideas?
Re: 5e3 bright channel problem
Have you tried new tubes?
Not much going on in that section so I suspect its the tube firstly, or the 68k resistor or input jack corroded?
telestrat
Post by telestrat »
Yes, it was a tube problem.
Thanks for your help.
Stick a 12AX7 in that spot.
