Just trying to scale some layouts for size...
what's the grid spacing on the vector boards I see used for a lot of the layouts around here...??
Vector board grid spacing
Re: Vector board grid spacing
Aurora,Aurora wrote:what's the grid spacing on the vector boards I see used for a lot of the layouts around here...??
Do you mean the vector board typically used for Trainwreck boards? Perhaps this post will help:
https://tubeamparchive.com/files/expres ... ut_180.pdf
Ah.. thanks alot Colossal!
Just knew I'd seen that - just couldn't find it again....
I've a large plate of 2.5mm FR4 I want to use with turrets or eyelets instead of buying boards
Ok! Glad it was of use.Aurora wrote:Ah.. thanks alot Colossal!![]()
