I turned over a repair this morning, an Ampeg R-12-rt, It has an original speaker.
Nice to see, had coupling cap issues and a couple bad resistors.
When ever I turned it off it would pop and fart..... phththththt....
and it turned out to be a bad filter cap in the PS the last one in the string.
It ran fine, no hum or buzz, just the fart at turn off.
Ampeg with gas
Andy Le Blanc
Ampeg with gas
lazymaryamps
Re: Ampeg with gas
Interesting, how did you diagnose that cap being the faulty one?
Andy Le Blanc
Re: Ampeg with gas
I rigged up a new cap with clips to ground and an old probe.
be damned if I wasted any $ on time or parts, a repair, not a restoration.
The client can't invest in restoration, few can, the amp will still need a proper recap.
I knew the sound the amp was making, been thru enough P, O, S old gear.
Component failures sound/smell different, a cap discharge sounds like a cap
discharge, just had to find which, and I'd already been thru the coupling for V leak.
lazymaryamps
