The Eagle Supre - Big SE Amp
angelodp
Cab
Post by angelodp »
Here is the temp cab, actually turned out ok for a junked 50's hi-fi cabinet I found on the street. I cut it down and made the grill work and interior supports etc. Old Fender handle on it. Marco says its cool he likes it. Snarls pretty well, the amp.
BTW threw in an EL34 today and it was very very good. It was tighter and more defined than either the 6V6 or the 6L6.
[IMG:576:647]http://i260.photobucket.com/albums/ii9/ ... 1/Mcab.jpg[/img]
[IMG:720:903]http://i260.photobucket.com/albums/ii9/ ... 3833-a.jpg[/img]
RJ Guitars
Re: The Eagle Supre - Big SE Amp
Post by RJ Guitars »
Hey that looks pretty good!
I want to thank you for following through and tweaking on this amp to bring out the goods with the 6L6GC tube. We'll see what other flavors we get with the various octal output tubes.
If you get a chance to do a sound clip or video I would really like to hear how she sounds.
Thanks for the hard work and sharing the lessons with us, I enjoyed watching this come together.
rj
http://www.rjguitars.net
RJ Guitars
rj
angelodp
NFB switch
Post by angelodp »
Just threw in a DPDT switch on the NFB line so I can have
5k - cleaner more headroom
None - Raunchy full on drive
10k - moderate feedback still with some grind
i think this may be the ticket for me..... at least until tomorrow.
Its a fun platform and learning a lot.
best A
yowza
Post by yowza »
How can I join the fun? How does someone order an Eagle Supre? I couldn't find specifics on RJ's site.
Thanks!
Colossal
Re: NFB switch
Post by Colossal »
angelodp wrote:Just threw in a DPDT switch on the NFB line so I can have
Awesome, nice work Ange. Did you come to any conclusions on how <i>The Raunch</i> sounded with 1 to 2M of feedback resistance as compared to none at all?? Hahah, that switch could be called the ZZTopBoost.
angelodp
switched
Post by angelodp »
The 1M/2M is about equal to the none. This switch allows for the drive to be normal as shown in the original schematic ( 10k ) or more Raunchy ( no loop ) or smoother ( 5k ). The Raunch position is a ZZ Top Boost. I suppose it could all be done with a pot that has an on/off switch on it.
[IMG:2295:1646]http://i260.photobucket.com/albums/ii9/ ... ixes-4.jpg[/img]
yowza,
Email rj for info his email address is in the post above this one.
If you have trouble let me know and I will call him.
RJ Guitars
yowza wrote:How can I join the fun? How does someone order an Eagle Supre? I couldn't find specifics on RJ's site.
Thanks!
I'll send you a PM and then we can set you up.
rj
surfsup
Post by surfsup »
Can't let ange have all the fun...did a few chassis mods today:
surfsup
Post by surfsup »
Ah,,,seeing the pics I see there's no hole drilled for the tone stack switch, or the HV line switch...so looks like i gotta do a bit more drilling - rats put all the stuff away already.
angelodp
nice....
Post by angelodp »
Surf, whats your layout or schemo looking like. We talking parallel pre & Power.
surfsup
Post by surfsup »
Okay so here's the chassis. A, I think I am going to use the extra tube for a loop, hence the two extra phono jack holes in back. I put an extra switch in while I was drilling to try to set up a "FAT" switch.
Extra octal is for a tube recto because I'm stubborn and don't believe all the experienced builders here that they are worthless in a SE amp. Even though they've all built 1000s of amps, they are clueless and I will prove it!
Okay so joking aside, I am going to do the rectotube anyway. Someone mentioned switching btwn the two? Maybe the HI/LOW will do something here.
[img:1280:768]http://chicagocadcam.com/ChrisHahn/supre/chassis1.jpg[/img]
[img:1280:768]http://chicagocadcam.com/ChrisHahn/supre/chassis2.jpg[/img]
Colossal
Post by Colossal »
Nothing wrong with a tube rectifier in an SE amp! They are great for getting the desired voltage drop. I think some confuse this with sag and that's not the case. Second, you have reduced rectifier noise (although FREDs and UF series diodes are really quiet so maybe that's a moot point) and third, it's another glowing tube! Nostalgia is part of the tube amplifier experience. I have some killer NOS rectifier tubes I hoard and secretly covet when I think no one is looking.
angelodp
loop
Post by angelodp »
You mean like a Dumleator loop? Yikes.
A
