I see a pot for variable feedback... give us a report back on that. Simple idea but a good one for changing the amp behavior.ToneMerc wrote:I just punched out this BF Champ layout so all I need now is is a chassis.
TM
rj
TM
Yep, it's a 20K (thought I had a 25K or 50K thumbwheel, no dice). Also, there's a switch in between it and the 2.7K FB resistor to disable the NFB loop if I choose too. I also moved the 15K bass resistor from pot down to the board, the intent is install a p/p pot or a mini switch to lift the tone stack.RJ Guitars wrote:I see a pot for variable feedback... give us a report back on that. Simple idea but a good one for changing the amp behavior.ToneMerc wrote:I just punched out this BF Champ layout so all I need now is is a chassis.
TM
rj
Thanks RJRJ Guitars wrote:I am also curious about the transformer set you've got. Looks a bit like the BF Champ set from Triode EL. I've got the pairs coming from Edcor but no choke in my design. I did ask Edcor to wind them with a 120/240 primary so that we can include a bunch more places in the world to build along with us.ToneMerc wrote:I just punched out this BF Champ layout so all I need now is is a chassis.
TM
rj
I'm looking at the Triode Champ OT in front of me and it looks the same. I'm sure MC stuff is as good as everyone says but I found this OT to be really lame in an ax84p1. The Edcor 10W I sub'ed ate it's lunch and dinner.ToneMerc wrote:OT: 8W, 5K, 4 & 8 ohm taps, no markings supposely USA made
RP, I'm not sure what brand it is although the lack of frame markings and single input Z is closer to this one offered by Mojo.rp wrote:I'm looking at the Triode Champ OT in front of me and it looks the same. I'm sure MC stuff is as good as everyone says but I found this OT to be really lame in an ax84p1. The Edcor 10W I sub'ed ate it's lunch and dinner.ToneMerc wrote:OT: 8W, 5K, 4 & 8 ohm taps, no markings supposely USA made
I'd say build it with what you have but plan on getting an Edcor from RJ when they come in. Holes will all be different.
I was looking at the one in that ebay link. That one looks identical to the Triode one. I wasn't sure which you were using. I think mojo uses more than one supplier too so who knows. I normally go for originality no matter how dinky and the original Champ was dinky. But the Edcor 5K/8/10W I swapped into the P1 really shone, so I was giving you a heads up.ToneMerc wrote:RP, I'm not sure what brand it is although the lack of frame markings and single input Z is closer to this one offered by Mojo.
surfsup wrote:RJ and tonemerc (or anyone else), since this is an amp for noobs, and I'm a noob, do you guys mind a coiuple questions?
1) The PT and PreT pinouts don't seem to exist on the web. I've checked Dr. Tube, and many other sites and can't seem to find which pins are which (I can tell which are the heaters but would like to figure out the schematic for this amp).
2) tonemerc's board is not the same as RJ's layout. What is that 20k component there in the middle/top?
3) Why the 16 and 8uF values on the smoothing caps? I seem to always see 47uF.
Usually it is me that drags things behind, but this time I actually have everything except the transformers here at the shop.xtian wrote:Edcor iron in yet?
The NFB loop is R13 in the schematic you posted yes?2) My layout is based on a Blackface (AA7 64) Champ. I couldn't leave well enough alone so I added a switch to disable the negative feedback circuit and also a 20k pot so that I can vary the FB resistance value from the original 22k down to the BF value of 2.7k.
R13-yessurfsup wrote:Tonemerc, a few more noob questions if you don't mind:
Your preamp layout vs. the soldered board seems to be reversed left to right?
If so, your 68k resistors don't match. Seems to be a 42R and a 240k Is that correct? The colors seem to be yellow red black and red yellow yellow on the two...
Is your 220k actually a 100k?
The orange line is going to run to pin5 of the 6v6 output tube?
The holes on the outside top/bottom of the board are to run connector leads underneath but have them come up to the top for possible repair convenience later?
